Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-22-2013, 05:12 PM
tboImpala tboImpala is offline
Question oil pressure low; stop engine???
This messege shows up everyday off and on throughout the day. I check my oil level and it's ok. I don't know what the issue could be. Help!!!!
Old 01-22-2013, 06:12 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: oil pressure low; stop engine???
The message shows up because the ECM is reading low oil pressure, NOT low oil level. You need to check (or have someone check) the oil pressure. You will cause major damage if you continue to drive it and it indeed has low oil pressure. You may also just have a faulty sensor. The oil pressure needs to be checked with a manual gauge.
Old 01-22-2013, 06:15 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
What year...? What engine...? Sounds like Oil Prassure Sending Unit is faulty, either internally or its wiring! That's the best case scenario, worst case scenario could be the Oil Pump going south!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 02-22-2013, 07:37 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: oil pressure low; stop engine???
Is the check engine light on? If so what is the code?
John
Happiness is driving a Chevrolet!
Old 05-15-2013, 11:13 AM
jonnik jonnik is offline
My '08 3.5 has done this 3 or 4 times over the last 4 weeks-putting the car in neutral will turn the message off. Where is the pressure sensor?
Old 06-06-2013, 04:08 PM
la1's Avatar
la1 la1 is offline
could be the pckup screen is clogged on the pump, or the the pump internally is bad, I seriously doubt it is a bad sending unit. you won't know till you get the pressure checked.
