Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-21-2013, 08:39 PM
peterpreuss peterpreuss is offline
Red face 2002 honda crv sensor fail
my 2002 honda crv shows check engine light and i checked it with a reader and it shows code p1166 h o2 s b2 s1 heater fail.how can i locate and replace it
Old 01-22-2013, 01:26 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 2002 honda crv sensor fail
Bank 2 is closest to the front bumper. Sensor 1 is before(on top) of the catalytic converter.
To replace it, simply unplug it from the harness, and take it out. very simple
The Following User Says Thank You to Greenblurr93 For This Useful Post:
peterpreuss (01-22-2013)
Old 01-29-2013, 11:42 PM
can u explain more please
Old 01-30-2013, 07:41 AM
Kind of a Big Deal
You have 2 exhaust manifolds. One is close to the firewall and the other is close it the front end where the radiator is. You want the one closest to the radiator. You'll see a metal sensor sticking out of it close to the top plugged into a harness. Unplug the sensor and remove it. Reverse the removal procedure to install the new one
Old 01-10-2014, 11:48 AM
sozine51 sozine51 is offline
2002 CR-V transmission trouble...?
Just bought the vehicle with 91,000+ miles. [As Is with no wqarranty] Shortly after I noticed some transmission shudder. There is also a bit of a whine in OD.
I changed the fluid twice using Honda's own brand. The old fluid did look brown and it obviously needed a change.Please help.
Car Parts
