Old 01-21-2013, 02:01 PM
Skirkbride Skirkbride is offline
Speedometer Not Working - High Idle
I have a 1993 Chevy Lumina V6. The Speedometer does not work. In addition, the it doesn't sound like it ever shifts. It runs the same in Overdrive or Drive. From a stop, you have to floor it to get going. It burns fuel like no tomorrow. It has had a tuneup. the other day, all of a sudden, on the Highway, the speedometer kicked in, and it started running beautifully. Shifting, stayed running when you started it, was getting great fuel economy. Then, just as suddenly as it started working, it stopped. So for almost 2 weeks, it would randomly work then quit. What could be the problem? I want to fix it, because let me tell you, when it kicks on, it is like an entirely different car, shifting, running smooth and not loud, and gets great fuel economy (for a Lumina). So please guide me here...
Old 01-21-2013, 04:43 PM
Tech II Tech II is offline
Re: Speedometer Not Working - High Idle
Sounds like a VSS(vehicle speed sensor)......would need to see if you are getting a speed signal from it on a scan tool....Rarely the ECM....
Could be the harness to it, connection to it.....could be the sensor is "apple cored"....
Old 01-21-2013, 05:19 PM
Thank YOU!! Now where would I find this bugger? Is it something they can run a code test for at AutoZone?
Old 01-22-2013, 12:31 PM
Schurkey Schurkey is offline
I had an 88 K1500 work truck that had an intermittent speedo. Turned out to be the instrument cluster that the speedometer gauge fits into.
When the speedo died, the cruise control, odometer, torque converter clutch, and ABS all quit working along with the speedo.
Good luck.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 01-23-2013, 12:16 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
+1 on the VSS. Just replace it, and make sure the harness isn't falling apart.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Tags
computer , idle , lumina , speedometer
