Old 01-20-2013, 10:54 AM
Stites Stites is offline
Dana 44 cross pin diameter?
Hey fellers! I posted this in the Rodeo forum as well, just figured you guys may know, too.
I'm going into our 97 Rodeo's rear end AGAIN!!! I've got a broken cross pin, and the weld job I did on it a couple months ago has finally failed. I'm hoping to find a good cross pin and weld it in, but if I can't find one, I'm not afraid to experiment with proper size bolts/rods/shafts/whatever the heck will fit in there and work.
Just one question, the answer of which has eluded me greatly... what's the diameter of the cross pin in a Dana 44?
For the record, I want this fix to last, but then if I can make it work till I can save up $150, then I can buy an entire axle unit with 25,000 fewer miles and put it in. Thanks for yall's help!
98% of fatal car crashes in the southern Appalachians begin with "Hey y'all, watch this!"
Old 01-20-2013, 10:59 AM
maxwedge maxwedge is offline
A990 racer
Re: Dana 44 cross pin diameter?
Give Randy's Ring And Pinion a call maybe the info is there.
