Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-17-2013, 12:53 PM
Panoz60's Avatar
Panoz60 Panoz60 is offline
I found them!!!!
In a previous post, I was looking for a way to simplify alignment adjustments. Well, I was net-surfing and found what I trying to describe what I was looking for when I saw on it another GTRA that I didn't buy. the link and the pic kinda explain themselves.. And..It's cheap!
http://www.howeracing.com/p-7566-internal-hardware.aspx
All you have to do is weld a plate on the outside of your current mounts, like this....
So.. loosen the vertical bolt in the upper picture, then use the horizontal bolt to make your adjustments, then tighten the vertical bolt again. Done!
Mark W.
Panoz GTRA, Chassis #10
Old 01-17-2013, 02:06 PM
CMPanoz CMPanoz is offline
Re: I found them!!!!
Our GTS has two adjustment bolts standard. The WC cars we have the nuts welded onto / into the frame but the bolts are missing. They do make adjusting camber easy.
Panoz GTWC 2
Panoz GTWC 3
Panoz GTS
Old 01-18-2013, 08:59 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
The only downside I see is that if you ever messed up the threads on that block you'd have to cut the front plate off to replace it.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
