Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-16-2013, 09:16 PM
busyb187 busyb187 is offline
96 eclipse gst wont start
Hello everyone. Well I have a little huge problem. I have a 96 eclipse gst turbo. The engine blew last week and I swapped the entire engine with an engine from a 97 eclipse gst turbo. Now, my car won't start. my ecu is from my 96 eclipse. Am I missing anything? Do I need to swap ecu as well? Anything will help. I've checked everything and power seems to be going to coils, fuel pump works, plugs are new. I'm lost... please help....
Old 01-17-2013, 07:11 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 96 eclipse gst wont start
Did the motor run before you swapped it into your car? Pull out a spark plug and check for spark while cranking. Make sure you are getting fuel pressure also. Odds are you either forget to hook something up or a connector isint making a good connection.
Thread moved
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
