Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-16-2013, 07:47 AM
buckeyes1967 buckeyes1967 is offline
Heater issues
confused. have a Ram 3500 diesel that is not putting out any heat. think it might be heater core but also checked for water flow but not getting any but engine is not overheating very confused figured if thermostat was bad and no flow would overheat any suggestions
Old 01-16-2013, 04:15 PM
DeltaP DeltaP is offline
Re: Heater issues
Check inlet and outlet temps of heater core they should be very much the same, hot. If not heater core might be restricted and needs to get back flushed or replaced. If both cold might check the heater valve operation. If not might be the controls and blend doors in the duct work themselves. How and where are you checking coolant flow?
Old 01-16-2013, 05:38 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Heater issues
The coolant temperature gauge on the instrument panel should show 190F after the engine is warmed up.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
