Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-12-2013, 08:33 PM
lopezf43 lopezf43 is offline
1989 gmc k15 4x4 automatic 3 problems
i have 3 concerns the first one my speedo only works when it wants ive already changed speed sensor took cluster out and cleaned all connectors . yet i got no change. number 2 fuel gage only works from 3/4 full to full another words at 3/4
im emty between 3/4 and full is half tank and full is full .I already changed sending unit and cleaned contacts on gage . no change. and last adle gos up to 1500 rpm i replaced IAC and TPS and MAP Sensor and EGR and some times it blows black smoke burn rich. can any body help. thanks
Old 02-21-2013, 05:56 PM
2000CAYukon 2000CAYukon is offline
Re: 1989 gmc k15 4x4 automatic 3 problems
Is the high idle all the time? If so, check the TBI gasket for a leak. Spray TB cleaner around the base, especially at the rear of the TBI unit. If the idle changes, the TBI gasket should be replaced.
//2000CAYukon
The Following User Says Thank You to 2000CAYukon For This Useful Post:
lopezf43 (02-21-2013)
Old 02-21-2013, 07:01 PM
cool thank you so much i will check it
