Old 06-06-2003, 04:39 PM
jusg19 jusg19 is offline
which manifold mpfi?
right now i have the 1.5 dpfi, i was wondering which manifold i need to use if i go MPFI. I plan on going to the LS b18a/b, so will the crx si mpfi swap work with the b series motor?
Old 06-06-2003, 07:10 PM
91civicDXdude's Avatar
yes. almost all honda MPFI wiring is the same, if its OBD0. OBD1 doesnt have the need for the resistor box, and also has differnt plugs on the injectors. If you're swapping in a 90-91 B18A1, which is obd0, it will plug right in. If you want to use an OBD1 B18A1/B1 you'll have to convert it to OBD1 by removing the injector box and using OBD1 injectors.
Old 06-06-2003, 09:08 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If you are saying you first want to convert your 1.5 to MPFI using a MPFI manifold you will need the 88-91 Civic or CRX Si Manifold. However that manifold will not work on a B-series, they don't work with D-series engines. But if you plan to swap in a B-series later the wiring is all the same as long as it is OBD-0.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-06-2003, 10:17 PM
hey..thanks for the info, Yeah i wanted to know if the d manifold would work with the b engine. well then i might as well wait til i get my b18.
thanks guys
jus
Old 06-07-2003, 01:16 AM
oops misread, just thought he wanted to know if the wiring was the same
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
MPFI Intake Manifold Wanted blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-25-2003 03:44 PM
88 CRX Si MPFI intake manifold 89 90 91 SWAP 1MYSTIKLXI '88 - '91 Civic | CRX | Wagon | Shuttlee 1 09-04-2003 11:21 PM
