Old 01-09-2013, 09:36 PM
boomboom boomboom is offline
Installing CPS on 1999 Caravan 3.3
I pulled the Crankshaft Position Sensor (CPS) out of the transmission bell housing on my 1999 Grand Caravan 3.3L, but I am not sure how to install it with the correct clearance. It will slide all the way in until it hits the flywheel. I found somewhere that it should have a clearance between 0.020 and 0.060. How do you set this clearance when there is no access inside the bellhousing. The mounting bolt hole has a slot in it so it can slide up and down a long way. Any tips? I looked these up on Ebay and it looks like there might be a pad that sticks to the end of the sensor to give it the clearance between the end of the sensor and the flywheel. Is this how the clearance is set?
Thanks.
Old 01-09-2013, 10:14 PM
jpb53 jpb53 is offline
Re: Installing CPS on 1999 Caravan 3.3
Yes put the spacer on the sensor an install.
Old 01-10-2013, 10:30 PM
Mbriggs Mbriggs is offline
I couldn't get the van to start when I installed it with the spacer, and I tried it multiple times. In the end I did it without the spacer and it has worked fine for 4 months. Could be that I got a substandard part. Hope yours works as directed!
00 Grand Caravan 295k - Acquired at 249k
07 Grand Caravan 178k - acquired at 150k
96 Honda Accord 185k
01 Saturn L200 165K
7 previous Caravans/Voyagers
