Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 01-09-2013, 07:42 PM
trs's Avatar
trs trs is offline
subwoofer
i have a 2008 equinox, just wondering if the 06-08 pioneer oem subwoofer enclosure will fit in a 2008 equinox, or what is similer that will fit, any make lol
thanks
trs
Old 01-11-2013, 06:40 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: adding factory subwoofer enclosure
I've thought about trying this too. I was basically going to use the OEM Pioneer sub & enclosure from the premium sound system and power it with an aftermarket amp.
The subwoofer and enclosure assembly (GM p/n 10393223 - includes subwoofer and enclosure) are the same from 2006-2009. The sub is 8 inches in diameter. The wiring diagram shows two pair of wires going from the factory amplifier to the subwoofer, so it is dual voice coil too.
(p/n 22727895 on sticker is no longer valid)
There is a sticker on the enclosure that says it is made by Pioneer and 2 ohms. I'm guessing that each voice coil is 2 ohms, but a quick check with a multimeter could determine this. I'd guess it could handle 100 watts RMS per coil at 2 ohms.
The subwoofer appears to be removable, so you may be able to replace it with an aftermarket sub of your choice. Although in the 2010-up Equinox the Pioneer sub is a little different and won't fit, it is about the same size. On their website, Pioneer notes that the 2010+ enclosure is about 15 liters in volume. This is a little more than .5 cubic feet which is sufficient for most aftermarket 8 inch subs.
http://www.pioneerelectronics.com/PU.../Chevy+Equinox
Just an FYI that the 2006 factory amplifier is different than 2007-2009.
You will also need the right rear body side trim panel that goes over the sub enclosure. These are also the same from 2006-2009.
Part numbers for Body Side Trim Panel (includes speaker grille & emblem)
15938698 (Ebony)
15938697 (Cashmere)
15938696 (Gray)
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
