Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-09-2013, 02:28 PM
vmvatbaby vmvatbaby is offline
Serpintine belt keeps breaking?!
I have a 2005 Chevy Impala 3.4. In the past 3 months I have gone through 3 serpentine belts, 3 tension pullies and the belt keeps breaking. The pullies all seem to be ok but i replace them cause they are under warrenty. I notice the belt over hangs the tension pulley about 1/8 inch. When the belt breaks it breaks at the 1/8 overhang at the tread. The only other issue I experienced on the drive line is on 2 occasions in the past 7000 miles the tempetures gauge went over the normal mark. oh and yes it squeals but with a little dry hand soap rubbing on track of belt temporarily relieves the squeal. All suggestions welcome.
Old 01-09-2013, 02:48 PM
Tech II Tech II is offline
Re: Serpintine belt keeps breaking?!
And you wonder why you have a problem? If the belt overhangs by 1/8", then you have an alignment problem....one of the pulleys is not in alignment, probably because a bracket is out of whack, or the tensioner pulley you have replaced is the wrong one....
Old 01-09-2013, 02:51 PM
How do I figure out which pulley is outta lined? The oem tensioner matches gm cross numbers so I m 99 percent it's the correct pulley. Thanks
Old 01-09-2013, 05:41 PM
brcidd's Avatar
brcidd brcidd is offline
I saw a 3.1 have the water pump wrapped wrong- running it backwards but still not over heating - are you sure your belt is wrapped right? smooth pulleys run on back side (smooth) of belt- ribbed pulleys use inside of belt
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-09-2013, 05:44 PM
That is a smooth pulley and the belt runs on back side
Old 01-09-2013, 05:56 PM
DeltaP DeltaP is offline
Tech II is correct. You'll have to get in there with a straight edge across all pulleys,2 at a time to see which one is out of whack. With belt removed check all pulleys first for excessive in/ out movement. Then make sure all accesories are mounted correctly and perpendicular to the belts travel. Make sure all pulleys are in the same plane.
