Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-09-2013, 12:50 PM
norms440 norms440 is offline
1997 Maxima strting problem
Hope this might help someone with same problem..1997 maxima 3.0..Starting problem...Very very hard to start...Some times no start..really bad when temp went below 30 degrees.come back hour later then would start..I replaced cam senor,both crank sensors,fuel pump, fuel filter,plugs,injectors,knock sensor,,I got fed up limped to the o' mighty Nissan dealer..Dealer told me $4,600 top fix..HAHAHA..they said trans had to be removed and mating surfaces needed cleaning.And needed a new complete under hood wiring harness.So I got 8 gauge wire..Battery terminal with stud and a wing nut,that I could put a bunch of ring terminals..Ran ground wire from battery to body,ground to starter belhousing bolt,ground to exhuaust hanger bolt under car,ground to intake manifold bolt, and last one to serpintene belt side of engine as close to crank sensor as I could..First try car started up and has been perfect ever since.Never ran better since I bought it 5 month ago..210,000 miles and still running like a champ..Hope this helps someone else..When in doubt "BAD GROUND"
Old 01-10-2013, 12:43 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 1997 Maxima strting problem
Originally Posted by norms440 View Post
...Dealer told me $4,600 top fix..HAHAHA..they said trans had to be removed and mating surfaces needed cleaning.And needed a new complete under hood wiring harness...
Me feeling sad for the dealer. How will they survive the harsh winter? Turn down (?) heating to save that 4600$...
Great story - repeated daily all around the globe at any stealership. Conspiracy - but just no theory (t)here...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
