Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-03-2013, 08:48 AM
2000bonny 2000bonny is offline
Voltage issues
I noticed last night on my way home from work that my headlights were flickering. I looked and also noticed my amp meter was also fluxuating. The car seemed to be running fine asside from the lights kept flickering. It did not make a difference what RPMs I was running, or even if the car was moving. My 2000 Bonneville has the original alternator and 181k on her, any pointers??????
Old 01-03-2013, 09:19 AM
aleekat aleekat is offline
Re: Voltage issues
test alternator output and battery. check all battery cables, etc...
Old 01-03-2013, 09:32 AM
Re: Voltage issues
All that appears ok. I am getting a pretty steady 14.8v output at the alt with the car at idle and watching the headlights flicker. I went and checked the dash amp meter and as that was happening, the meter was fluxuating quickly from about 12-15. I also checked the voltage going directly to the headlights and it is stable at 14.4v.
Old 01-03-2013, 12:55 PM
Re: Voltage issues
Don't be surprise if your alternator goes out. Could be the brushes wearing out. I would double check all the grounds you can find.
