Old 01-02-2013, 01:48 AM
dingguya's Avatar
dingguya dingguya is offline
Cool [911 Tribute] 993 Turbo (Italeri 1:24)
My entry into the 911 tribute is the Porsche 993 Turbo. It's the very last air-cooled 911 and my favorite car of all time. Some day I will own one!
Anyways.. this kit is the same as the Revell version (which is a rebox of this one). Apparently it's quite a rare kit, but I was lucky to be able to find one about 7-8 years ago.
Here's the box (not my picture):
I started by correcting some of the fitment problems. First of all, the sideskirts that are glued on are not right near the rear wheel arches. As you can see on the original car, they are flush with the wheel arches instead of sticking out:
So that was sanded down. However, there's a groove underneath that needed to be filled up. As I don't have putty, I took a lid of a "I Can't Believe It's Not Butter!" cup and cut out a very small strip and glued it on.
That's now drying and waiting to be sanded down.
Next, the mirrors don't fit properly. I cut a larger hole where the mirrors are supposed to be attached and glued them in. Of course, I cut the hole a little too big and again had to fill this up with a tiny piece of plastic:
The front bumper comes loose easily so it need some support:
So here's how she stands at the moment, waiting to be sanded down and some primer.
For the body color I was thinking black, like the one in the picture above
Stay tuned!
Back from a 6 year modeling hiatus.
I also run Street Hockey Nut, a site about street & ball hockey.
Old 01-02-2013, 02:17 AM
rallymaster's Avatar
Re: [911 Tribute] 993 Turbo (Italeri 1:24)
Nice work so far, I'm tuned for sure !
Phil
Old 01-02-2013, 07:21 AM
denilsonvm's Avatar
denilsonvm denilsonvm is offline
Good start! wheels on this model are not aligned in the rear axle.
Old 01-10-2013, 02:57 AM
dingguya's Avatar
While the body is undergoing some putty work (yeah I bought some putty ) to fix a bad looking panel line, here are some shots of the chassis, brakes and suspension parts. As you can see I weathered the underside of the chassis a bit with some sandpaper (have yet to do the flat black parts).
More soon
Old 01-10-2013, 03:03 AM
Orion37170's Avatar
Orion37170 Orion37170 is offline
Send a message via ICQ to Orion37170 Send a message via AIM to Orion37170 Send a message via MSN to Orion37170
looks good so far. have you made any choices on the wheels yet?
Old 01-10-2013, 03:30 AM
dingguya's Avatar
Looking to build this one stock. Though may have to go with the 996 wheels instead.
Old 01-10-2013, 03:36 AM
Orion37170's Avatar
yes, those coming with the kit are really tiny
got a set of boxster rims for mine, but they don't look as i expected...
996 but tamiya, not italeri too; right?
Old 01-10-2013, 06:55 AM
dingguya's Avatar
Yeah the Tamiya 996 Carrera wheels are supposed to look better. The Italeri ones are indeed pretty small.
Old 01-10-2013, 04:46 PM
drunken monkey's Avatar
Razor Sharp Twit
hmm, that looks like my photo...
AF's Guidelines
Read them.
Old 01-10-2013, 11:33 PM
tonioseven's Avatar
Nice start so far!!
Old 01-11-2013, 03:45 AM
dingguya's Avatar
I think I found it somewhere on this forum but now I can't find it anymore. If you're not cool with me using it I can take it down?
Old 01-11-2013, 11:27 AM
Razor Sharp Twit
no no, it's fine.
I was just in that little-bit-shocked phase because I'd completely forgotten about taking that photo.
Anyway, I've mentioned it to another member who built (or rather, started building it a while ago) that the kit isn't 100% accurate.
The biggest flaw is that the chassis is the wrong one; it being a simple re-use of the older chassis used in the 964 cars. If you're an accuracy nerd, the Tamiya GT2 kit chassis fits under the body.
The second smaller flaw is that the main body shell doesn't have the wider rear wings.
It's only 1mm on either side when scaled but if you add them on, it makes a big difference to how it looks.
The head lights could do with replacing too and again, the Tamiya kit has good replacements.
Of course, there's the wheels.
Wrong size and too small.
Other than that, you might want to check how it all fits together before you fix the interior tub to the chassis plate.
If I recall, the rear part of the chassis has to fit over the engine bay's hinge part and this can't be done if it's all been fixed together.
AF's Guidelines
Read them.
Old 01-11-2013, 11:15 PM
dingguya's Avatar
Thanks, very helpful tips! I'll be sure to do some serious dryfitting before glueing things together. Don't really care about the chassis as you won't see it anyway
I noticed the radiator over the engine doesn't really fit, so I'll have to figure something out for that. Also, there are no headlight buckets supplied in the kit so I'll have to scratchbuild something for that or salvage them from a previously built kit.
The wheels are definitely 2-3 scale inches too small, but unless I can find some separate wheels I'm not buying a whole new different kit just for the wheels.
It's not the best kit indeed, but it's the closest one to an accurate 993 Turbo. I'm wondering if the Revell kit is truly a 100% re-box or if it did fix some of the Italeri's flaws (like the headlight buckets) though..
Anyway, engine is done:
Old 01-12-2013, 07:13 AM
Orion37170's Avatar
i have the Revell box and it is 100% the same kit
Old 01-12-2013, 10:21 AM
Robi J's Avatar
Robi J Robi J is offline
Separate wheels
http://www.scaleproduction.de/produc...19--turbo.html
overall external diameter 27.60 mm
rim external diameter (the visible lip) 22.15 mm
width F/R 13.00 mm
Robi
