Old 01-01-2013, 08:18 PM
BE Snowplowing BE Snowplowing is offline
Crazy Brake Lights
I have a 2000 Silverado 1500 4X4 extended cab with short box with a 5.3L.
First let me say that I use the truck as a snowplow so it is used in snow salt etc.
A couple weeks ago I noticed that my brake lights were staying on all the time. I removed the fuses for the trailer left and right lights and the brake lights went out. due to the holidays I haven't had time to find out why the lights were staying on.
Today I noticed that my 3rd brake light was staying on all the time, even with the truck off, and no one in the truck, and my electric brake controller inside the cab was on. I unpluged the controller from the fuse panel and the controller light went out but the 3rd brake light was still on. I couldn't find a fuse, so I removed the bulbs. Can anyone please tell me where I would start to find the problem.
many thanks
Brian
My Vehicles:
1989 Chev 3500 4X4 6.2l Deisel
1994 GMC Suburban 4X4 5.7l
1998 Buick Regal 3.8l
2000 Silverado 4X4 5.3l
Old 01-01-2013, 10:44 PM
tempfixit tempfixit is offline
Re: Crazy Brake Lights
Have you checked the brake switch on the brake pedal??
Old 01-02-2013, 09:15 AM
j cAT j cAT is offline
many thanks
Brian
remove the STOP LPS 20A FUSE . if the lights go out then it will be the stop lamp brake pedal switch needs adjustment or replacing.
Old 01-02-2013, 10:23 AM
jcat
I removed the fuse and the 3rd brake light stayed on. hahaha I have no idea, how you can remove a fuse and the light stay on
My Vehicles:
Old 01-02-2013, 11:31 AM
aleekat aleekat is offline
Don't rule out the brake pedal switch. Most 3rd brake lights run independent of the main brake lights. Those normally route through the steering column/turn stalk system.
Old 01-02-2013, 01:44 PM
jcat
there are many fuses. did you remove the one I suggested ?
Old 01-02-2013, 04:28 PM
DeltaP DeltaP is offline
jcat
Brake lights and 3rd brake lights are 2 separate circuits protected by separate fuses. But they both run through the pedal mounted brake light switch. Thats most likely your problem.
Old 01-02-2013, 04:45 PM
the fuse I mentioned for HIM to remove feeds the brake pedal switch [hot at all times]. those other lower amperage fuses are further down the feed line, and lower amperage.
removal of this fuse mentioned should reveal if it is or is not the brake pedal switch.
the feed to the brake pedal switch does feed the rear brake lights as well as the high mounted brake light.
Old 01-03-2013, 07:05 AM
Sorry everyone, I have been out non stop snowplowing.
Tonight when I get home I will remove the fuse that j cAT told me to remove and post my findings. Thanks again everyone for your help and input.
My Vehicles:
