Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-31-2012, 09:01 PM
molczak714 molczak714 is offline
Temp guage reading low
I have a 98 trans sport and the temp gauge is reading low. Only on the first line when driving then when i pulled into the garage it went up one line and heat got warmer. Felt both upper and lower hoses and i can press them both in Fluids are full no leaks anywhere. oil is good tranny fluid is good. I just got it on a trade it runs and drives great no problems at all.
Old 12-31-2012, 09:10 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Temp guage reading low
My first suspicion is your thermostat is stuck open, allowing the full flow of coolant through the radiator all the time.
This device is supposed to stay closed until the coolant at the top of the engine reaches about 195 deg F. Even then it will not open all the way, but just enough to maintanin temperature.
BTW this is not just an inconvenience for lack of heat. It wastes fuel, because the engine control system thinks the car is on a cold-start mode and makes the fuel mixture richer.
Also, it accelerates engine wear.
New thermostats are cheap, about 10 bucks with the gasket, and installation is relatively easy.
If you get a new one, you must get the 195 degree version to ensure your car functions properly. There might be 180 and possibly 160 deg versions. These are for specialized applications and are not appropriate for most cars and driving applications.
The Following User Says Thank You to MagicRat For This Useful Post:
molczak714 (12-31-2012)
Old 12-31-2012, 09:31 PM
Thanks i will pick one up and start there
Old 12-31-2012, 09:39 PM
grease_monkey1975's Avatar
grease_monkey1975 grease_monkey1975 is offline
thermostat, like magic rat said
Old 01-01-2013, 05:02 AM
WelmoedJ's Avatar
WelmoedJ WelmoedJ is offline
Alike others I suspect the thermostat.
It might even be possible there's no thermostat at all.
This often happens when a car with cooling problems is on sale, they just remove the thermostat to make the system look like it's working and avoid the costs of replacement.
Welmoed
De Lorean DMC-12 1981-11
Toyota Prius III 2009-07
Old 01-01-2013, 08:32 AM
Tech II Tech II is offline
If you've never done one before on this kind of engine, it's not that easy....
Old 01-01-2013, 02:09 PM
i will swap it out. I know its a pain in the ass to get to under the throttle. I got the right tools though to reach in there. The bottom bolt on those has a notch in the housing so i just need to remove the top bolt and loosen the bottom one.
