Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-28-2012, 08:22 PM
molczak714 molczak714 is offline
98 trans sport multiple problems
Hey guys i have a 98 i just took it up on a trade. The sliding door on passangers side its automatic it wont open i hear something clicking but its not going. Other problem is the windshield wipers only work on high any ideas?
Old 12-29-2012, 09:17 AM
500hpgtx's Avatar
500hpgtx 500hpgtx is offline
Re: 98 trans sport multiple problems
On our 1995 Transport 3.8L, I go to the right rear wheel well area of the cargo section and remove the panel. I unplug and reconnect the connectors at the circuit board for the sliding door. I also unplug and re-seat the other connectors related as well. I have done this so often, I can perform this in about 2 minutes. Any time a seat belt gets in the door sliding area probably confuses the electronics for the sliding door. Another way that is used on the 95 TS is removing the fuse in the fuse panel for the sliding door(glove box area?) for a few minutes and re-seating. Not certain which fuse.(brake lights maybe)
Our windshield wipers were acting erratic. I replaced the circuit board for the wiper motor. LMP (member) found re-soldering the solder joints at the connector for the circuit board would solve intermittent problems. I have not
had any experience with wipers working on High only. Possibly the same answer. Good Luck
Old 12-30-2012, 11:31 AM
played around today and found out that the bottom track wheels were not sittin in. Now the door opens from time to time and it closes but then when it closes and i put it in drive it buzzez. Rand the test and its puttingout code 23 now
