Old 12-28-2012, 04:21 PM
jazziesdad jazziesdad is offline
Security Light?
I have a 98 F150 4.6 XLT, ok had to replace the battery, but when I put the cable on I heard the doors lock, so I go around to start it up, and I get nothing, no clicks, nothing, I look down on the dash, really beside the headlight switch and this little red light was blinking, now I've owned thiis truck well over 10 yrs and this light has never came on before, so I disconnected the battery and reconnected and the light went off, the truck started right up, what am I missing here?
Old 12-30-2012, 05:16 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: Security Light?
if it isn't in the cluster labeled theft it is an aftermarket alarm/interupt system.
-=-=-DANE-=-=-
Old 12-30-2012, 09:05 PM
Re: Security Light?
it's not in the cluster, so how can I find out what the deal is?
Old 12-30-2012, 09:10 PM
Re: Security Light?
Search under the dash for a box that normallu looks like it doesn't belong or follow the wies from the light back to it. Then if you didn't have it installed remove it. Some of the wires will go to the steering column. One wire will be cut and hooked to the box. Remove them and reconnect the original wire (this is the srart wire).
-=-=-DANE-=-=-
