Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 12-27-2012, 02:35 PM
Ferny_71 Ferny_71 is offline
Unhappy How to disable anti-theft mode on 2003 Saturn ION
I posted before for problems to start the car, after some inspections was found that the anti-theft is getting acttivated disabling the car.
How I can disable the anti-theft system?
re-programming the ecm ?
replacing the ecm?
The car is:
2003 Saturn ION 2.2L MFI DOHC 4cyl
Old 01-01-2013, 03:24 PM
bernteck bernteck is offline
Re: How to disable anti-theft mode on 2003 Saturn ION
Can't disable
If the system is not working then the cause of the failure will need to be diagnosed and repaired.
Old 10-22-2013, 10:58 PM
jokersfb jokersfb is offline
If you can start the car, once started, you can cut the white wire attached to the plug for the ignition switch. You will see it when you tilt steering up and look at sterring colum from under neath. This will put the pass lock in an error mode and will no longer disable vehicle. Your pass lock light will be on all the time but will work.
