Go Back   Automotive Forums Car Chat > Ford > Granada | Scorpio
Old 12-26-2012, 04:50 AM
thetandycollector thetandycollector is offline
Send a message via MSN to thetandycollector
Merkur Scorpio: What trans to install?
Hey everyone, I've got an 88 Merkur Scorpio, bought it from the second owner in 2007, had it off and on since. It's always been a complete bastard about eating front pump (converter, input shaft) seals. I think it's probably only been driven about 4k miles since I bought it and it's been through 3 seals.
Took the trans out to rebuild it and put the car in storage in early 2010. Tore the trans down to find a mangled mess inside. Car drove fine with the exception of a hard first to second shift. All the thrust washers where warped and oval shaped, and a lot of the plastic spacer washers where either gone or smashed. Consulted OnDemand5 about this and it says the transmission was recalled at one point due to a warped center support (mind you, this was information provided through OD5 about this transmission, but not in this specific vehicle) and that it could cause all the internal issues I was seeing, up to and including a constant need to replace the tailshaft seal or front pump seal. Checked out the center support and indeed, it is warped. Can't seem to get a good center support, so I figured I'd go with a salvage transmission. Issue is, nobody around here even knows what a Merkur Scorpio is, let alone what parts will interchange with it.
One junkyard says their computer shows an 87 Ranger in stock with an A4LD trans that will mount right up, BUT the valve body would have to be swapped for the one from my car. Is this true? And, are their any vehicles available in the US that would have the same transmission that would be a literal bolt-in-and-go type of deal, or will they all require some form of modification to work properly? Any input would be great.
Bill S.
76' F250 "Camper Special" Utility
90' E350 XL Diesel "Vuck" Dually - TRADED 7/14/14, see next:
1998 Ford E-SuperDuty 450 14' UHAUL MRU - V-10 Auto, less than 100mi on engine and trans.
93' Cadillac Allante'
88' Merkur Scorpio *getting trans in the next 45 days* 7/14
86' C30 3+3 Dually - 96k orig mi, 1 owner
28' Benz SSK Replica (Put a 351W in a Pinto and you'll get the idea.)
1996 Chevy K1500 Suburban - FOR SALE
Amongst many other idiot purchases.
