Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 12-24-2012, 01:08 PM
brdufrain's Avatar
brdufrain brdufrain is offline
93 Deville
Im trying to program keyless entry remotes for a 93 Deville i bought trouble is where they say to use jumper wire on data link connector in diagram conector has 12 pins trouble with mine is only 6 of those pins have wires connected to them so were it tells me to run jumper wire there is wire on one A on diagram but no wire on other marked G on diagram so im puzzled
ANY HELP WOULD B APPRECIATED THANK YOU
Old 12-24-2012, 03:27 PM
maxwedge maxwedge is offline
A990 racer
Re: 93 Deville
You must be using instructions for a 95-96 up sysem, yours is obd1 in 93.
Old 12-25-2012, 11:09 AM
brdufrain's Avatar
Re: 93 Deville
so here would i look for that
and thank u for answering
Old 12-25-2012, 12:00 PM
aleekat aleekat is offline
Re: 93 Deville
search this forum
The Following User Says Thank You to aleekat For This Useful Post:
brdufrain (12-25-2012)
Old 12-25-2012, 01:31 PM
brdufrain's Avatar
Re: 93 Deville
thank you for advise only came up with one other than mine here and again not right for my vehicle
Old 12-25-2012, 01:41 PM
Re: 93 Deville
Says it works of a 93.
1. Turn ignition switch to off.
2. Jumper Assembly Line Diagnostic Link Connecter(A.K.A ALDL connecter located behind center instrument panel, below ashtray) terminal G. (PPL/WHT) to terminal A (BLK/WHT). Doors lock and unlock, and trunk release activates in approximately 2 seconds.
3. Press any button on one transmitter. Door locks lock and unlock, and trunk release activates in approximately 2 seconds. The first transmitter is now programmed.
4. Repeat step 3 using the other transmitter. If only one transmitter is being used, go to step 5.
5. Disconnect jumper from ALDL connecter.
Check to see that both transmitters operate door locks, repeat steps if necessary.
Old 12-25-2012, 01:47 PM
brdufrain's Avatar
Re: 93 Deville
after further reveiw ive found that because the dlc has no metal strips in the g slot and 5 other slots of the twelve pin connector that the car has no keyless entry installed in the vehicle which i no is hard to believe in a cadillac i would like to thank everyone for there help with this
