Old 12-18-2012, 02:57 PM
mrstg65 mrstg65 is offline
trailing arm trouble
Hello,
1999 Pontiac Grand Prix SE 3.1 litre 197k miles.
Recently became noisy on bumps. An inspection of the drivers side rear wheel
showed me why. The mount on the frame that the trailing arm connects to has rotted out. It looks like a changeable part as it is bolted to the frame, but I do not know what it is called and cannot find it in any parts catalog. Has anyone else had this problem? Thanks for your thoughts.
Old 12-18-2012, 11:38 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: trailing arm trouble
Try an auto dismantling yard. I suspect this is not a normal wearing part, so I am not surprised you cannot find a new one.
Whats the one on the passenger side like?
The Following User Says Thank You to MagicRat For This Useful Post:
mrstg65 (12-19-2012)
Old 12-19-2012, 08:09 AM
rickisrad rickisrad is offline
If the bracket itself is corroded away you may need to get one fabricated at a body shop
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
Old 12-19-2012, 01:59 PM
Tech II Tech II is offline
If that is corroded, I would be concerned with the front cradle, brake lines, fuel lines, etc.
The Following User Says Thank You to Tech II For This Useful Post:
Old 12-19-2012, 03:59 PM
Thanks for the fast replies...The passenger side is rusted also but not as badly..this rust appears on the bracket itself which bolts to the frame which appears to be intact. The brake and fuel lines look as you would expect on a 99. There is not much rust on this car. The trailing arm itself is not broken and the bushings are in fair shape as well. I know a guy who works the parts counter at a GM dealership. I will ask him if there is any such part and post back the results.
Old 12-20-2012, 04:19 PM
Thumbs up Re: trailing arm trouble
Hello again,
Went to see the dealer today...turns out it is GM part number 10262701 description is simply "bracket". List price $13.28 plus tax. My friend told me that he has sold quite a few of them this year. I guess this is strictly a dealer part. The new one is a very light gauge metal. If the original part was the same I am surprised it lasted this long. I plan on changing both sides next week. Thanks again to you all.
Old 12-20-2012, 09:30 PM
MagicRat's Avatar
Thank you for the update.
I didn't think GM could price a sneeze that low.
Old 12-21-2012, 07:27 AM
I would do both for that price. You should paint them before putting on to help prevent future corrosion since they are a lighter gauge steel.
