Old 12-17-2012, 08:29 AM
desimunda desimunda is offline
shaking when starting sometimes - every 10th time or so..
not sure where I should begin. Van is well maintained but has 250K km on it.
Old 12-17-2012, 10:14 AM
tempfixit tempfixit is offline
Re: shaking when starting sometimes - every 10th time or so..
Please explain, does it shake while cranking to start or after engine has started??
More info please.
Old 12-17-2012, 01:23 PM
More info please.
It does this after engine has started.
Old 12-17-2012, 06:02 PM
12Ounce 12Ounce is offline
I'm assuming no codes were initiated. ?? If that is the case, a failing fuel pump would be high on my list of "usual suspects"!
Old 12-17-2012, 06:58 PM
scubacat scubacat is offline
Of course change that fuel filter first!
Old 01-07-2013, 04:18 AM
parkerb parkerb is offline
my '00 does a rough idle after startup for 5 seconds from time to time. i've thought it to be the IAC but i have not chased it further. 200k miles so far on the original IAC.
Old 01-15-2013, 06:21 AM
This works great. I sprayed the throttle body cleaner after sliding off the intake hose and cranking RPM....so far so good!
