Old 12-14-2012, 08:07 PM
jbander jbander is offline
Break trouble , keeps going to floor
I have a 96 voyager, it has been a great car for the last 10 years I've had it. My brake peddle goes down to the floor, it gives brake but I think barely and my brake light comes on. I have Bled it twice and changed the master cylinder , neither worked, I'm perplexed, my mechanic thinks it is the abs any other thoughts. I would really appreciate any advice you may have.
Old 12-14-2012, 11:06 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Break trouble , keeps going to floor
I assume you have checked the entire system for leaks. If you properly bled the system after the master cylinder replacement, it is possible the there is some internal leakage in the ABS unit causing the pedal fade. Depending on the quality of the master cylinder you used, you may also have a bad part...
Old 12-14-2012, 11:36 PM
******* Thanks much for the response. Well the master cylinder was new just a few months ago and another one was put in didn't change a thing. There is no loss of brake fluid , wouldn't that be totally apparent if there was a leek. I'll ask the mechanic what he thinks about just another bad master cylinder. Thanks any other ideas.
Old 12-15-2012, 03:14 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
They are bleeding the MCs separate from the rest of the system either on a bench or on the van correct?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
jbander (12-15-2012)
Tags
abs , brakes
