Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 12-14-2012, 02:59 AM
army army is offline
2005 sonata noise
i have a 2005 sonata and every time i go over a bump that is a litle bigger than normal the rear underneath the car makes a banging noise like something is loose i visully checked underneath the car trying to manuly move stuff but couldnt find anything loose does anybody have any ideas as to what i should check more closely thanx
Old 01-20-2013, 07:14 PM
Slow_n_ez Slow_n_ez is offline
Re: 2005 sonata noise
You might have already checked but, open trunk and lift the cover over spare tire , make sure the twist knob is very tight on tire and it doesn't move , plus check to make sure the jack and other stuff isn't loose ....
Old 02-23-2013, 06:02 AM
feldetestas feldetestas is offline
I was the same, I think you're right, something in the trunk or in the spare wheel.
If you find it, tell us, thanks
http://www.taxibasauri.es
Old 03-07-2013, 07:34 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Check the top mounting bolt of the rear shocks, I recall reading about a problem there causing a noise like you describe.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 10-27-2013, 07:24 PM
the rear control arms buhings were shot both sides replaced with new control arms problem fixed what was also happening the rear tires were wearing pretty bad
