Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 12-13-2012, 10:02 AM
Gally Hill Gally Hill is offline
Fault Code P1137
Hi All
Last week driving home from work, a short journey of approx 4 miles I noticed my EM light on.
I own a VW ProScan so I plugged it in and got the following reading
17545 - 226 01/01
KWP 2000
Fuel Trim : Bank 1
(add) : system too Rich : P1137
sporadic 002 - Lower Limit Exceeded
The car had not lost any performance and had no mpg issues
I reset fault code
Last night driving home again it came on again, I have driven over 200 miles since it first came on with no problem
until last night. Rechecked and the same reading again.
I have had my Passat 2.0 Sport (petrol) since new (2002- mileage 62,000) and this is the first time I have had the EM light on.
Has anyone else has had this problem. The car is performing well even with the light on, but I do not want to damage the engine. should I get a VW dealer to check it out. The car is serviced every year
Thanks
Paul
Last edited by shorod; 12-13-2012 at 09:59 PM. Reason: Removed links to another forum.
Old 12-20-2012, 10:02 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I would check and clean the mass air flow sensor. Also have a good top engine clean and injector cleaning done followed by an oil change.
Also might be time for a front oxygen sensor replacement
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 12-21-2012, 05:32 AM
Re: Fault Code P1137
Thanks For your help
I will clean the mass airflow sensor if I knew where it is, I will check manual. Also I will replace the front oxygen sensor, and clean injectors. Can you use the injector cleaner you add in the petrol tank or is it a strip down of injectors ?
Once again Thank You for your help
Paul
