Old 06-06-2003, 03:17 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
TIP: removal of tyre mold lines
No matter how good the manufacturer (i.e Tamiya) there is always going to be the central mold seam on the tyres. Road tyres are the worst when what with all the tread to consider when trying to remove the seam.
I've tried a fresh scalpel blade, but I found that I could never get a clean enough cut, there is a threat of slipping and taking away a few blocks of tread and it usually takes ages.
I've tried sanding, but this is not that easy either as the seam is thin and flimsy and you end up taking more rubber off than required. You also don't cleanly remove it either.
Well, here's a solution I stumbled accross last night when working on the Aoshima Exclusive Matrasse wheel set. The 'tool' I used was a nail clipper. It was perfect! As the cutting edge is curved for your fingernail, it was ideal to clip around the circumference of the tyre. You can get in very close, as the rubber is fairly self healing. I managed to cleanly remove the seams off four tyres in a matter of a couple of minutes.
Hope this of help to you.
Old 06-06-2003, 03:24 AM
primera man's Avatar
"P-Man"
Nice tip...never thought about using them before
View All My Models Here.
Old 06-06-2003, 03:27 AM
GTi-VR6_A3's Avatar
GTi-VR6_A3 GTi-VR6_A3 is offline
H4X0R T0 T3H M4X0R
Send a message via AIM to GTi-VR6_A3
great tip i have been using it for ages just never thought to post it the clippers also work well for trimming the plastic away from pieces and for cutting off of the trees. my gf showed me when she was building a gundam
-GTi-VR6_A3
-GTi-VR6_A3
Old 06-06-2003, 03:39 AM
chipanggo's Avatar
chipanggo chipanggo is offline
Hmmm. Interesting. I'll try that. :flash:
Old 06-06-2003, 04:47 AM
mel79's Avatar
mel79 mel79 is offline
I've given the mold seam a coat of superglue to harden the rubber. After that it's very easy to sand off. I think this method works better on slicks (I usually coat the whole thread surface and then sand it to give it a used look) but it isn't impossible to use on normal tyres either.
-Mikko
Old 06-06-2003, 05:21 AM
Mikko,
Would this not leave white residue all over the tyre?
Old 06-06-2003, 08:44 AM
Cychalen's Avatar
Cychalen Cychalen is offline
Great tip! Thanks for sharing.
You should have posted this tip 24hrs earlier. I already spent ages trying to remove mold lines on 8 tires.
12 more to go...
Completed.
Datsun 240Z #5 Monte Carlo Rally 1972
Working on.
Nissan Primera
Old 06-06-2003, 08:52 AM
12 more to go...
Well, now you can get them done in a matter of minutes
Old 06-06-2003, 09:10 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
How do you guys remove the mold lines from the inside of the wheel?
Old 06-06-2003, 09:39 AM
Why would you need to?
I haven't tried it, but I suppose you can turn the tyre inside out and adapt the method(s) above.
Old 06-06-2003, 10:09 AM
captain_karma captain_karma is offline
another thing that works well is cuticle scisors the cutting blades are only about 3-4 cm long, they are usually very sharp and they come in both straight and curved blade variety. I get mine from where my wife gets her beauty stuff.
Old 06-06-2003, 10:54 AM
T\/\/iN-Tu|2Bo's Avatar
T\/\/iN-Tu|2Bo T\/\/iN-Tu|2Bo is offline
Cool never thought of nail clippers before!
"If you feel in control. You're not going fast enough" - Mario Andretti
Old 06-06-2003, 11:52 AM
BOOSTD's Avatar
No dude you misunderstood. I said the wheels not the tyres. I bought some Fujimi Model 5's and the mold lines are shocking and because they are long spokes you can see the mold lines really badly through the wheel.
Old 06-06-2003, 12:30 PM
Alien's Avatar
Alien Alien is offline
Thanks for the tip, realy saves alot of time and sandingpaper:flash:
Old 06-07-2003, 01:03 AM
Murray Kish Murray Kish is offline
Getting Old...
I had a poor set of wheels with a bad seam that was hard to get rid of. I actually used little bit of lacquer thinner on a q-tip and rubbed it lightly over the seam. Be very careful if you try this because the lacquer thinner basically 'melts' the rubber. If you're careful, you can melt the seam away and a light 'scuff' with sandpaper seems to finish everything off.
Murray
