Old 12-11-2012, 03:15 PM
tempfixit tempfixit is offline
Removing sludge in engine thoughts
Has anyone ever tried using about 1 quart of desiel fuel in a normal temperature operating engine, then drive a 2 or 3 miles then drain the oil and change filter to see if that will help remove sludge in engine???
I know dump truck owners have added desiel fuel to there engines and run a few miles then changed oil, doing this procedure with every oil change and No damage to bearings.
Any thoughts
Old 12-11-2012, 07:28 PM
12Ounce 12Ounce is offline
Re: Removing sludge in engine thoughts
... so they actually opened up the crankcase and inspected the bearings? What some folks do for the team!
Old 12-11-2012, 08:05 PM
I canot say that they removed the bearings and inspected. they have driven many miles without any problems.
I personally had a injector stick open on the truck I drive and it dumped a good amount of desiel fuel into oil pan before I caught the problem, only clue was the fuel consumption was more than usual. I have driven the truck another 30,000 miles since this happened without any failure.
Most owners will inspect and install new rod and main bearings as a preventive measure around 300,000 miles, with or without adding desiel fuel before oil changes.
I know antifreeze will eat up bearings.
Old 12-12-2012, 04:36 AM
DeltaP DeltaP is offline
Turns Delo 400 into 0W-20.
Old 12-12-2012, 06:23 AM
I don't have much experience with a diesel engine ... other than stationary generator sets and my old '85 Mercedes (near 400k miles now). I have always been impressed with how clean the diesel is internally in the crankcase. Yes, new oil blackens straight-away, but the "stuff" seems to stay suspended in the oil. I have never seen sludge deposits on diesel internals as I have seen on gasoline engine internals.
In your experience with the stuck injector: Was it a diesel engine? If so, wonder why the diesel fuel didn't keep the injector from sticking? Did the injector break internally?
Old 12-12-2012, 09:23 AM
Yes it was a desiel engine, I do not know if the injector broke internally. I would suspect so as the injectors are not contolled by electronics rather by a injector pump driven by crankshaft or camshaft, not sure which.
The reason I am asking this question is that some engines have poor oil passages and are prone to sludge blocking them and eventuallycausing the oil light to flicker on and off at idle and eventual engine failure. Just wondering if the diesel fuel could help clean the oil passages and prevent the oil pressuure loss.
Old 12-12-2012, 02:30 PM
Grabber5.0 Grabber5.0 is offline
I thought the motor flush products that you put in you oil before changing it (idle for a few minutes, most say not to drive the vehicle) were similar to deisel fuel. I think I have heard of people using diesel fuel to do this, but I don't know its effectiveness.
Old 12-13-2012, 05:36 PM
wiswind wiswind is offline
The engines used the the Windstar, 3.0L and 3.8L don't have a reputation for developing sludge in normal service.
A reasonable Oil Change Interval with a quality oil and filter should be all that you need to do.
The issue that can come up with a "flush" product in a sludged engine is that you can clear a BUNCH in a hurry and end up clogging the intake tube screen for the oil pump......starving the engine of oil.
A quality synthetic or a High Mileage (HM) oil should be all you need for light buildup.
Another product is Auto RX that gently cleans over time.
Again.....you should be fine with a quality oil and filter and a reasonable Oil Change Interval.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-13-2012, 07:10 PM
I am not refering to the Ford engines, The Chrysler 2.7L engine is know for sludge problems and a nieghbor has one. The oil galleys become sludged causing blockage and eventually staarving the bearings of oil and causing catastrophic failure. This is reason for asking for thoughts about desludging engines.
I will do some research on AUTO RX.
Old 12-13-2012, 07:13 PM
Originally Posted by tempfixit View Post
The reason I am asking this question is that some engines have poor oil passages and are prone to sludge blocking them and eventually causing the oil light to flicker on and off at idle and eventual engine failure.......
I'm probably not getting the proper picture in my old brain-pan! The flickering light is caused by low oil pressure, ...sensed by a pressure switch, correct? So if sludge somehow blocked the oil passages, restricting oil flow ... wouldn't that make the pressure go higher at the warning light pressure sensor? Mind you, the crank and rod bearings might be getting fried ... but the pressure sensor would be happy as heck!
When I see a low pressure light flickering, I think the oil pump is not pumping enough oil for some reason ... OR ... there is too little restriction to oil flow, such as too much wear space between bearings and crank throws, etc, etc.
Old 12-24-2012, 08:33 PM
schadd1971 schadd1971 is offline
I have heard of a product called Auto RX..might look it up...
Old 12-24-2012, 10:50 PM
I looked it up and it looks like something to use . Spendy but still a lot cheaper than a new vehicle or engine.
Old 12-25-2012, 09:52 AM
yeah,,,and doesn't sound too drastic or crazy and shouldn't hurt to try it...compared to some radical ideas that could risk engine damage......
Old 12-25-2012, 09:55 AM
I have used the Auto RX product.
I would NOT put engine flush products or diesel fuel into the oil.
You buy Auto RX online from their website.
Follow the directions on their website.
I have also used this product, as instructed on their website, for my automatic transmission.
The only varience I did was I had it in there somewhat longer then they specify and I also had a Magnefine filter installed in the transmission fluid cooler line.
1996 3.8L Windstar
Old 12-25-2012, 11:01 AM
scubacat scubacat is offline
Engine cleaning products make me verrrrry nervous. Dislodged sludge can be a ton more damaging than a little that's harmlessly built up on engine components. I wouldn't risk it. If sludge is a real problem, a rebuild might be in order. (At least pulling the valve covers and seeing the state of the top). I haven't heard of sludge issues with windstar engines anyway. I have a camry with the 1mzfe that's known for sludge and even that appears fine to me. [i think it's really just a problem for people who don't change their oil but that's a discussion for another day]
