Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-10-2012, 04:51 PM
dldecks dldecks is offline
2001 chevy impala blinkers
2001 chevy impala front blinkers wont work, when the blinker switch is turned on rear blinkers run fine but fast like a front bulb is out, Ive replaced the bulbs and the hazzard switch still have no front blinkers, any suggestions would help
Old 12-11-2012, 10:37 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 chevy impala blinkers
Do the fronts flash when you use the hazard switch? If they do, the problem is likley in the turn signal switch.
Old 12-11-2012, 06:08 PM
Yes the front blinkers work when the hazzard button is on, if the blinker switch activates the rear blinkers makes sense that the switch is working I was hopping not to have to buy a $375. part to see.
Old 12-11-2012, 06:36 PM
aleekat aleekat is offline
$375, maybe from the dealer. Quick search as low as $140.
Old 12-11-2012, 07:08 PM
gmtech1's Avatar
The switch has two seperate circuts for the front and rear turn signals, it's possible that the circut for the ft signals has failed...a schematic and some testing would tell for sure.
