Old 12-09-2012, 04:07 PM
GTKSmoke GTKSmoke is offline
91 buick lesabre heater blower
I have a 1991 Buick Lesabre..getting no power to the heater fan..any ideas?
Old 12-09-2012, 04:28 PM
big white bufflo big white bufflo is offline
Re: 91 buick lesabre heater blower
it could be the blower relay located in the duct work under the hoodor a blown fuse
Old 12-10-2012, 10:34 AM
Tech II Tech II is offline
If manual system, could be resistor block.....check all fuses first....check power at harness into the resistor block....
Did you check for power at harness to blower motor with a test light or voltmeter? Should use a test light...should get progressively brighter with change in speed....
