Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-08-2012, 02:56 PM
tkswan's Avatar
tkswan tkswan is offline
Upper control arm - lower ball joint
On a level-of-difficulty-scale from 1 to 10. 10 being the most difficult. How difficult is it to change the upper control arm and the lower ball joint?
-tswan
Old 12-09-2012, 10:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Upper control arm - lower ball joint
I'm not ignoring you, but don't have the experience to answer either question. When I tried to replace the lower ball joint on a my wife's former 2002 LS I was unable to get on it straight enough to press the old joint out. Since the bad wheel bearing hub was also corroded in to the knuckle, I ended up just ordering a new knuckle with ball joint installed figuring the ball joint would be at least as corroded as the hub.
I never tackled the upper control arm/upper ball joint on her car.
If interested, I can e-mail a PDF of the steps according to the factory service manual for the upper control arm. Since the factory does not consider the ball joints replaceable by themselves, they won't have steps for replacing just them.
-Rod
Old 12-09-2012, 12:25 PM
tkswan's Avatar
Thanks Rod. Please email the pdf to me.
-tswan
Old 12-20-2012, 06:35 PM
tkswan's Avatar
Im going to have it done. I dont want to deal with the spring.
-tswan
