Old 12-07-2012, 09:42 PM
Elk1007 Elk1007 is offline
Ridin Dirty
Question 93 Accord LX, 2 problems
I just bought a used 93 accord. The engine is in good shape and runs smoothly most of the time, but I have two issues.
First, when I start the engine cold, there is a very loud belt squealing for about 3 or 4 seconds. Is this a common problem and, if I isolate the belt at fault, what should I do about it?
Second, the engine revs (both audibly and on the tach) when I press on the breaks. I've been told by a friend it might be a vacuum leak? Any ideas?
Thanks for your time
Old 12-07-2012, 11:55 PM
ProMan ProMan is offline
Re: 93 Accord LX, 2 problems
For your first issue, you need to replace the driving belts. Make sure you clean the pulleys thoroughly before you install the new belt, and make sure they are at the proper tension.
The Following User Says Thank You to ProMan For This Useful Post:
Elk1007 (12-08-2012)
Old 12-08-2012, 01:33 AM
Ridin Dirty
Thanks for the reply
So you know it's the driving belts just from what I've described?
Or is it just an educated guess?
Old 12-08-2012, 03:38 AM
Ontiveros Ontiveros is offline
I agree with what ProMan said...
The Following User Says Thank You to Ontiveros For This Useful Post:
Old 12-08-2012, 09:05 PM
Ridin Dirty
Can anyone comment on my other problem?
Old 01-24-2013, 12:33 AM
Soheel Ali Soheel Ali is offline
Hi, If there was a vacuum leak, your engine would be adling above 900 rpm always, and when you push the brake padel, all vacuum is finished.
Just check which RPM you are adling at. Normally the idling goes higher when you play with the brake padel after 5 or 6 pumps.
Tags
1993 , accord , revving , squeal
