Old 12-02-2012, 12:27 AM
caboclo3 caboclo3 is offline
97 grand caravan SE shuts off ,has 50 psi fuel pressurel pre
Very puzzling situation here. Got a 3.3 engine with 150K , starts fine ,but shuts off when put into drive. This is an intermittent issue that started recently. Thinking it was a fuel pump or fuel filter issue from a bad fill up,I removed the tank,drained it,cleaned it, installed new fuel pump with new primary and new secondary fuel filter, and put in 6 gallons of clean gasoline. Cycled the ignition switch several times, bled air from fuel rail,and started it up while monitoring fuel pressure. It holds @ 50 psi but when I put it into gear just stalls out. Had new engine computer installed by dealer less than a year ago , and car has run great ,with no issues till now.Any ideas what to look for next?
Now the van won't even start/fire.It just turns over.Great fuel pressure tho!
12-5-12 Very happy to report that because of the info given in the response down two,the van is now running again. While locating the crankshaft position sensor we found that the cps wire had come apart at the connector. This happened because of previous transmission rebuild work, and because the 2 holding clips on the connector were broken off. We fixed it by reconnecting and tightly wrapping electrical all around the connector, to keep it from coming apart again. Hope this will help others with same issue.
Old 12-02-2012, 06:18 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 97 grand caravan SE shuts off ,has 50 psi fuel pressurel pre
It's acting like the torque converter is locking up the tranny. Not sure how to prove it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-03-2012, 08:53 AM
jpb53 jpb53 is offline
Does it have spark? Here is a sight that might help.
http://troubleshootmyvehicle.com/chryslers
The Following User Says Thank You to jpb53 For This Useful Post:
caboclo3 (12-05-2012)
