Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-01-2012, 07:33 AM
barossu19 barossu19 is offline
01 Jimmy front drive shaft
2001 Jimmy 4wd, 115,000 miles; Recently I noticed a strong vibration when in 4WD, no vibration in 2wd. I found that the rear joint (at the transfer case) of the front drive shaft has play in it. I am assuming that this is the problem. It has the appearance of a CV joint. Is that joint rebuildable or do I need to replace the shaft?
Thank you.
Old 12-01-2012, 09:06 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 01 Jimmy front drive shaft
You will need to replace the shaft. They use a "cardan" joint in there and it is not serviced seperatly.
The Following User Says Thank You to gmtech1 For This Useful Post:
barossu19 (12-01-2012)
