Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 11-28-2012, 07:19 PM
cobrahd1999's Avatar
cobrahd1999 cobrahd1999 is offline
Question 2000 Sable rear brake line question
Hello I have a broken line the goes to the wheel cylinder and wondering if they make a replcement part or do you have to make your own. I also have to change the cylinders so I would need that line for both sides. Why couldn't been a rubber hose. lol
thanks for any help.
Have a great day
Frank
Disabled Vietnam Vet 68-69 US ARMY Brothers Forever..
"The trouble with the Vietnam War it killed so many that survived"
"That's all I have to say about that. "( Forrest Gump)
Retired Carpenter Local 272 Chicago
Old 11-29-2012, 08:49 AM
65comet's Avatar
65comet 65comet is offline
Re: 2000 Sable rear brake line question
There are the rubber lines that go from the body to the brakes to allow the movement for the suspension. If you're replacing the metal it is a good idea to also replace the rubber. The pressure is extremely high and the rubber breaks down over time and from the constant bending. Also completely replace the brake fluid. It absorbs water moisture over time and that is a chief contributor to line rusting. Part stores have straight lines in stock of various lengths. So you can bring in your old lines and see if they have something close. They also rent benders, cutters and flare tools if you need them to make the straight ones match what came off your car. They may also be able to order exact size replacements, or you can check with the Ford dealer or check some of the online parts websites.
