oil pan gasket
i need to know if i can change the oil pan gasket without taking exhaust offon 2000 tarus with 3.0 ohv.have bad leak at front of oil pan.any advice would be apperciated.
thanks charles |
Re: oil pan gasket
Removal
VIN "S"? 8th didgit of VIN. I'm gonna say it needs to come off... ![]() 1. Remove the LH exhaust manifold to pipe nuts. 2. Raise and support the vehicle. 3. Remove the front RH wheel. ![]() Zoom and Print Options ![]() 4. Remove the RH front inner wheel splash shield. - Remove the screws and the pin-type retainer. ![]() Zoom and Print Options ![]() 5. Disconnect the RH Heated Oxygen Sensor (HO2S) electrical connector. ![]() Zoom and Print Options ![]() 6. Remove the exhaust bracket bolt. ![]() Zoom and Print Options ![]() 7. Disconnect the LH HO2S sensor electrical connector. ![]() Zoom and Print Options ![]() 8. Remove the RH exhaust manifold to pipe nuts. 9. Support the exhaust system. ![]() Zoom and Print Options ![]() 10. Remove the nuts and the Y-pipe. - Discard the gasket. 11. Drain the engine oil. - Install a new drain plug gasket and tighten the drain plug to 27 Nm (20 ft. lbs.). ![]() Zoom and Print Options ![]() 12. Remove the bolts, nuts and the engine to transaxle bracket. ![]() Zoom and Print Options ![]() 13. Remove the torque convertor inspection cover. ![]() Zoom and Print Options ![]() 14. Remove the 18 bolts and the oil pan. Installation 1. Clean all sealing surfaces on the engine and the oil pan with Metal Surface Cleaner F4AZ-19A536-RA or equivalent meeting Ford specification WSE-M5B392-A. 2. Position a new gasket on the oil pan. ![]() Zoom and Print Options ![]() 3. Note: The oil pan must be installed and the bolts tightened with in six minutes of sealant application. Apply a 10 mm (0.40 inch) diameter dot of Silicone Gasket and Sealer F7AZ-19554-EA or equivalent meeting Ford specification WSE-M4G323-A4 to the areas indicated. ![]() Zoom and Print Options ![]() 4. Position the oil pan and hand tighten the oil pan to transaxle bolts. ![]() Zoom and Print Options ![]() 5. Tighten the oil pan bolts in the sequence shown ![]() Zoom and Print Options ![]() 6. Tighten the oil pan to transaxle bolts. ![]() Zoom and Print Options ![]() 7. Install the torque convertor inspection cover. ![]() Zoom and Print Options ![]() 8. Position the engine to transaxle bracket and install the nuts and the bolt. ![]() Zoom and Print Options ![]() 9. Position the Y-pipe and gasket and install the nuts. ![]() Zoom and Print Options ![]() 10. Install the RH exhaust manifold to pipe nuts. ![]() Zoom and Print Options ![]() 11. Connect the LH HO2S electrical connector. ![]() Zoom and Print Options ![]() 12. Install the exhaust bracket bolt. ![]() Zoom and Print Options ![]() 13. Install the RH front inner wheel splash shield. - Install the screws and the pin-type retainer. 14. Install the RH wheel. 15. Lower the vehicle. ![]() Zoom and Print Options ![]() 16. Install the LH exhaust manifold to pipe nuts. 17. Fill crankcase to proper level with Super Premium SAE 5W-30 Motor Oil XO-5W30-QSP or equivalent meeting Ford specification WSS-M2C153-G. © 2012 ALLDATA, LLC. All Rights Reserved. |
Re: oil pan gasket
To change an oil pan gasket?? That is the most
ridiculous thing I ever heard. Only a Ford engineer could come up with that!!
