Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 11-28-2012, 08:09 AM
dylanborns dylanborns is offline
Help with front bank upstream O2 sensor
I replaced 3 of the 4 O2 sensors and tried working on the front bank, upstream sensor today. It is so tight in there, that I could barely get the O2 socket up in there with a wrench on it. I had to resort to an adjustable socket wrench with the head turned to a pretty sharp angle which was putting alot of incorrect stress on the sensor when I turned it. It didn't budge, and I was worried that putting anymore torque on it would bust it off. I tried working from underneath the vehicle and also down through the top, but nothing worked.
Any suggestions on getting this thing out?
Old 11-29-2012, 08:05 AM
65comet's Avatar
65comet 65comet is offline
Re: Help with front bank upstream O2 sensor
I had heard about that one being so hard, so when I had to replace the radiator I put in a new sensor at the same time.
On another note, regularly check your coolant reservior to see if tranny fluid is floating on top. The factory radiators like to crack internally swapping fluids. It doesn't take long for antifreeze to seize up a transmission as I found out. My wife was the daily driver at the time and she thinks she just has to put gas in and everything else takes care of itself. So maybe you'll have to get two with one stone and with an easier access to that sensor. Though it sucks to pay for the radiator, it sucks worse to also pay for a transmission.
Old 11-29-2012, 09:34 AM
I was thinking that the only easy way to get to it was going to be to remove the grill and radiator. I think I'll hold off on that sensor until I have a problem with it. Meanwhile, the check engine light came on again yesterday and its showing a problem with the rear bank, upstream sensor. That one is only about two weeks old, so I don't know what the problem is with it now.
Thanks for the info
Old 11-29-2012, 11:46 AM
tempfixit tempfixit is offline
Thanks for the info
What is the code number? Probably a broken wire instead of a bad sensor.
Old 11-29-2012, 04:48 PM
I'm pretty sure it was P0155, which was the rear bank, upstream sensor. Today, I unplugged it, and disconnected the ground on the battery. Once I hooked it all back up, everything was reset, so I went through the steps to reset the PCM. Twelve miles into it, the check engine light came back on. I noticed when I put the new sensor in that the connection doesn't "click" as it locks into the female connection. Even when I go to unplug it, I don't have to move that locking tab for them to come apart, so for some reason its not locking together correctly.
I'll check out the wiring tomorrow, thanks.
Old 11-29-2012, 05:25 PM
P0155FordHO2S-21 (Bank 2 Sensor 1) Heater Circuit Malfunction
Old 11-30-2012, 02:37 PM
I just took a look at it and the tab must have broken off of the female connection from the computer. There is a place on the male end of the sensor wire where the tab should lock in, but its missing on the other connector. I was able to get a pair of pliers down in there and get it tightly connected, but I'll have to drive it a little to see if that helped.
Old 11-30-2012, 09:49 PM
DeltaP DeltaP is offline
Isn't the "grille side" of the engine bank 2?
Squeezing the piss out of it with pliers will probably damage the connector shells and distort the pins, affecting their contact. Just squeeze it together firmly with your hands and loop a ty-wrap through the wires from each plug end,male and female then cinch it up tight. If you find the plug is damaged and the contact of the pins questionable you can just verify the wiring connnections and crimp them together with heat shrink butt connectors.
If the P0155 returns you'll have to inspect the heater circuit not just the sensor. You should probably clear the codes with a scanner/ code reader so you can verify they are cleared and there is nothing else pending. You'll also know when a drive cycle is completed.
Old 11-30-2012, 10:02 PM
[quote=65comet;7013537]I had heard about that one being so hard, so when I had to replace the radiator I put in a new sensor at the same time.
__________________________________________________ __________________________________________________ _____________________
Just wait till ya gotta change the alternator!
Old 11-30-2012, 10:18 PM
Bank 2 is on the driver side or on a front wheel drive ford the bank closest to the radiator. I believe this is the sensor you have not changed correct?? Yo may want to recheck the codes stored.
Old 11-30-2012, 10:35 PM
That's exactly what I was thinking.
Old 12-01-2012, 07:49 AM
If Bank 2 is the side next to the radiator, then that is the sensor I am having trouble with. The one that is in the worst possible spot.
Old 12-01-2012, 08:44 AM
65comet's Avatar
[quote=DeltaP;7013761]
I already changed the alternator. Gotta thread somewhere about it. Because of a frontend accident, the normal area to squeeze it out was compressed a little small, had to actually unbolt and move the engine forward.
Old 12-01-2012, 08:54 AM
Originally posted by 65 comet: I already changed the alternator. Gotta thread somewhere about it. Because of a frontend accident, the normal area to squeeze it out was compressed a little small, had to actually unbolt and move the engine forward.[/quote]
Is that what you figured out for yourself? Front end accident or not you'll be spinning that alternator over and over like a "Rubic's Cube", trying to get it out. Until you remove the CV axle!
Old 12-01-2012, 11:24 AM
Ok, so I had it reread and it is the front upstream sensor. I checked the wiring and it doesn't look to be damaged from when I worked on it, but I can't really see the top of the sensor where the wiring connects. If there is damage to it, thats probably where it would be since I was using the socket right there.
I'm not able to get to this in the next week, so besides possibly having lower gas mileage, what will driving this cause if I wait about a week?
I know that these things are heated for some reason, but what exactly is a "Heater Circuit Malfunction"?
