Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-25-2012, 09:52 AM
caddiali caddiali is offline
97 regal noisy compressor
My 97 regal has a noise from the compressor clutch. It goes away when the a/c is turned on. Mechanic said its the clutch assembly. Is this easy to change?
What causes the noise to go away when the a/c is turned on? Just curious...
Thanks for the feedback!
Old 11-25-2012, 10:04 AM
DeltaP DeltaP is offline
Re: 97 regal noisy compressor
Probably a worn clutch pulley bearing that gets locked in and supported by the compressor when the clutch is engaged with the a/c on. It takes some special tools that you probably dont have.
The Following User Says Thank You to DeltaP For This Useful Post:
caddiali (11-25-2012)
Old 11-25-2012, 11:49 AM
brcidd's Avatar
brcidd brcidd is offline
Don't have to guess on this one-- see it a lot- here is my cut and paste on it:
This sounds like classic v-5 clutch drag- the air gap has tightened and needs to be adjusted back to .020" . I have answered this several times- and usually see about 1 a week during the hot season. The noise is a scrapping/rattle only with a/c off- should see signs of metal shavings about the clutch hub. The fix is to borrow the installer/removal tool from autozone and back off the air gap a tad. This can be done on car, without removing compressor or refrigerant, and can even be done without removing the shaft nut since the nut does not bottom on the clutch drive. Pull back the plastic cover in wheel well to access
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Old 11-25-2012, 01:58 PM
Too bad it wont last.
Old 11-25-2012, 03:07 PM
brcidd's Avatar
I've done about 300 like this- never had a comeback- not sure what you are referring to that won't last....
'99 GMC Yukon
Old 11-25-2012, 04:32 PM
Thanks guys great knowledge from the pros....I will get my mechanic to get a replacement....your details into the problem is helpful!!
Old 11-25-2012, 04:38 PM
brcidd's Avatar
No replacement necessary- the armature plate is dragging on the pulley face due to corrosion behind the stops holding the armature plate too close to the pulley face- the iron filings collect on the clutch hub due to magnetic pull and the results of continued dragging and wear- the fix is to pull driver out to .020" gap- It stops scrapping when the a/c is on because both armature plate and pulley are turning together- no scraping when they are magnetically bonded when a/c is turned on.
'99 GMC Yukon
