Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 06-05-2003, 10:31 PM
FlexinTwinZ FlexinTwinZ is offline
Stuttering 1990 300zx TT after 5000 RPM
The car takes off fine up to 5000 RPM, then starts to stutter through the redline, then continues to accelerate after the shift with awesome power, but then stutters after 5000 RPM's again. I've been told I may not be getting enough fuel past 5000 RPM's. Readings don't indicate that. I've also been told a plug or 2 may be bad. I'm running Denso Iridium Power Spark Plugs, (colder IK24) 5311 (part number). The Turbos spool up at am getting max boost without any leaks and no signs of detonation. What's up? Help?!?
Old 06-06-2003, 02:33 PM
Z Babe's Avatar
Z Babe Z Babe is offline
Re: Stuttering 1990 300zx TT after 5000 RPM
Originally posted by FlexinTwinZ
The car takes off fine up to 5000 RPM, then starts to stutter through the redline . . .
It sounds like the turbocharger wastgate is seizing, or not opening freely. Have you checked the wastegate valve and actuator operation?
There could be a number of possible problems, including lack of oil supply to turbocharger; damaged turbocharger bearings; dirt/oil deposits caked on compressor wheel and/or diffuser vanes; fuel system defective or not properly adjusted; dirty air filter; and restricted exhaust or block cat.
Have you scanned the ECU? If so, what was the readout?
Z ya! Z Babe
_______________
My Entire Z Collection
The Georgia Z Club
Old 06-19-2003, 10:09 AM
Duh!
I found out the next day it was the large "s" hose that connects to the back of the balance Tube. It was crimped when I put the plugs in. Thanks though!
1990 300ZX TT Stage V+ (new Project)
1990 300ZX NA Stage I
2005 350Z Twin Turbo (Next Project)
