trany fluid
I put 11 quarts of trany fluid in, it still slips. Should I put in anymore fluid?
Re: trany fluid
Year, mileage. Did you Flush the complete tranny??? or did you remove tranny pan and change filter???? Need more info. |
Re: trany fluid
Its a 99 4l60e. Don't no the milage. Its used, and I just instaled it. Win I took the pan off it had maybe one third of a quart. The guy never said if he completely flushed it or not. All I no is there's 11 quarts in it and it still slips a lil. I no that when u just do the pan it should only be 5 quarts, well at 5 it sure at hell was goinging nowhere. Is this enough info? Be glad to give u more.
Re: trany fluid
Was the torque convertor empty??? Original converotr or did this one come with the tranny?? Was the transmissionn cooler in the radiator flushed???
Have you checked the level on the tranny dip stick after it is to normal operating temperature??? What type of fluid used??? What does the owners manual say for tranny fkuid quantity??? |
Re: trany fluid
The torque converter came with the trany. I'm not sure how much was lft in it but I put about one third trant fluid in it. I did not flush the radiator. It is full win running. I used dex/ merc max life. And I'm pretty sure its eathere 11 or 12, I havnt lookes.
Re: trany fluid
if the old transmission had a failure you should flush out the radiator tranny fluid cooler lines. if the replacement tranny is a known good one the torque converter should be with no issues , like need to be cleaned or replaced with a rebuilt one. you always install with a drained transmission about 5qts then start and continue to add until its at the full cold mark with the engine at idle in neutral. then place in gear and fwd/rev. then neutral to check fluid level on the stick to at the cold mark. if then the transmission does not move the vehicle ,you have a defective replacement .. the fluid you used is dexron VI. good fluid. never operate the vehicle with the fluid level over the full mark. the fluid will create air bubbles and the tranmission will soon die. |
Re: trany fluid
If those cooling lines are not as tight as possible,could that cause it to slip
Re: trany fluid
internal damage does cause the transmission to cause your problems. a pressure check is a start on the troubleshooting. I would get my money back from the guy who sold you this junk. |
