Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 11-24-2012, 11:49 AM
sevenoutseven sevenoutseven is offline
Replacing turn signal switch in C5
Is it a lot of work to replace the turn signal switch in my 1999 Corvette? I bought a replacement but not sure if I can do it. Signed, Steve's wife.
Old 11-24-2012, 02:01 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Replacing turn signal switch in C5
It's a fair amount of work, mostly trim that has to come off. The steering wheel and the air bag need to come off, the trim around the top of the column also needs to come off. Unplug the harnesses to the multi-function switch, one screw on top of switch and one in the front of the switch. If you decide to do it yourself, be sure to disconnect the battery and then wait 20min before removing the air bag, this will allow time for the capacitors to bleed off. Also, a puller is sometimes required to remove the steering wheel.
The Following User Says Thank You to gmtech1 For This Useful Post:
sevenoutseven (11-24-2012)
