Old 11-24-2012, 04:23 AM
Daf57 Daf57 is offline
2010 Mustang undercarriage color question
Hi,
New to the forums - thanks for having me!
I'm building the Revell 2010 Mustang GT - while doing some reference photo gathering I ran across the shot linked below. Anyone have a source for or idea of what color that mid section is? Kind of a semi-gloss beige or tan but with a definite metalic tone. I also found some undercarriage shots that were simply black-ish - not sure the standard for the 2010s. Thanks for any suggestions!
Daf
Old 11-24-2012, 01:36 PM
935k3's Avatar
935k3 935k3 is offline
Re: 2010 Mustang undercarriage color question
It looks pretty close to Duplicor's Self Etching Primer. It does dry flat so a coat of semi-gloss clear would be needed.
The Following User Says Thank You to 935k3 For This Useful Post:
Daf57 (11-24-2012)
Old 11-24-2012, 03:47 PM
Hey, that does look close - thanks! I'm going to see if I can find a can. Would the etching primer be too hot for plastic you think? Better try it on some scrap first...
Actually the site says
A high-quality formulation allows for maximum adhesion under all types of automotive finishes on plastics, fiberglass, bare steel, aluminum and stainless steel surfaces.
So sounds like it would be safe.
Thanks again!
Daf
Old 11-24-2012, 07:01 PM
935k3's Avatar
It probably is too hot for styrene plastic without a coat of regular primer put down first. I airbrush it on metal parts. I think Autozone carries it.
Old 11-25-2012, 06:23 AM
hd221813's Avatar
hd221813 hd221813 is offline
Here another picture. It seems a non metallic primer to me.
Alberto Michelatti
Old 11-25-2012, 11:38 AM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
I agree w/ 935k3, if you use that definitely put down a primer on the plastic prior to using the etching primer. Its hot enough to etch metal for better grip, so I'd be kinda scared to see what it would do to bare plastic.
And yes, Auto Zone does carry it, I've purchased it there several times to use on my pickup.
Tags
color , mustang , undercarriage
