Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-24-2012, 12:09 AM
Dodge King901 Dodge King901 is offline
Exclamation Luke warm heat
Hey there AF...i am having a heat problem...first my temp gauge never goes above 160...second...my return heater hose is not hot...my upper radiator hose is tight when I squeeze it
Old 11-24-2012, 02:11 PM
aleekat aleekat is offline
Re: Luke warm heat
Sounds like thermostadt issue.
Old 11-24-2012, 02:32 PM
Re: Luke warm heat
Ok ill try it and update the thread...thanks
Old 11-27-2012, 12:47 PM
Re: Luke warm heat
Ok..i went to put the thermostat in only to notice that there isnt one in...i asked a guy at a shop anout it and he sed it pronably got tooken out to cover up a pressure leak...how tru is this???
Old 01-06-2013, 04:46 PM
Re: Luke warm heat
Jus to update the thread...i replaced thermostat due to it being stuck open...since I replaced it my temp gauge started working again...i flushed the heater core..now I have ok heat (still not hot tho)...but only when the fan setting is on the first and second setting...even on full blast it feels waaaay cooler....other than that it runs fine
Old 01-06-2013, 05:23 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Luke warm heat
What temperature thermostat did you install? Can usually get the them from 165-195deg ratings.
Old 01-06-2013, 05:52 PM
Re: Luke warm heat
Still may have some air in the system.
Old 01-09-2013, 07:56 PM
Re: Luke warm heat
Not sure what temp it was...i wanna say a 182° or 192° t stat...ill take it out to make wut degree it is...i doubt there is air in the system...i had that truck running for a good 30-45 min to make sure.no.bubbles appeared
