Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-21-2012, 04:11 PM
TCHRISD TCHRISD is offline
Ram radio harness help....
I have a '98 dodge ram single cab pickup. I removed the factory basic tape player AM/FM radio and installed a new radio. Well I don't like my new radio and want to put the factory back in. Problem is I removed all the wire from the harness to connect to the harness for the new radio and I forgot which slots the wire go into on the old harness. The male ends are still on the wire so I can just snap them back into the harness.
Can anyone help me with the wiring order?
Old 11-21-2012, 06:42 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Ram radio harness help....
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
The Audio section starts on page 424.
There's some wiring in the Wiring section.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-24-2012, 07:56 AM
thanks but the harness on my radio is just one piece and not two harnesses like showed in the pics. I wonder if I have a different year radio in it????
Old 11-25-2012, 09:05 PM
AF - Advisor
Since the manual is '01 and your Dodge is a '98, there must be a difference.
Sometimes it hits and sometimes it misses.
Old 11-26-2012, 08:25 AM
aleekat aleekat is online now
this may help.
http://www.installdr.com/Harnesses/DCP-Wiring.asp
Old 11-26-2012, 09:01 AM
Originally Posted by aleekat View Post
Thanks for the try but this is showing the same 2 piece harness.
Mine is a one piece with 16 holes. Although all 16 are not used. One piece divided into two sides of 8.
Old 11-26-2012, 11:20 PM
One piece at the bottom.
