2002 GT Light and Engine Issues...
Need some help folks. First issue is my rear right turn signal went out. I replaced the bulb, still out. I replaced the socket, still out. All fuses are good, none blown. Do I need to replace the whole rear wiring harness? If so I am having trouble locating one, any ideas?
Second issues: My engine stalls out on start up...most of the time. If I pump the gas hard it usually won't stall. If it stalls it does it in the first 5 seconds. When the headlights get brighter after the 5 seconds or so, that's when I know it's good to go. No other stalling issues other then start up, thoughts? Thanks for the help! |
Re: 2002 GT Light and Engine Issues...
Did you check for power and ground to the turn signal circuit?
If I pump the gas hard it usually won't stall. If it stalls it does it in the first 5 seconds. When the headlights get brighter after the 5 seconds or so, that's when I know it's good to go. Which engine? Not sure what you mean by headlights? |
Sorry, should have better explained the headlight thing. When I start the car it is always sluggish for the first 5 seconds or so OR it stalls out completely. How I gage that time frame is when my headlights get brighter (after the 5 seconds) I know I can put it into gear without stalling it.
As for the wiring, you going to have to be elemetary with me as I'm not great with the electrical stuff. Hope this helped a little. |
I would have the battery tested. It's possible to be on it's way out and such thing can cause lots of weird problems.
Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
