Old 11-20-2012, 10:46 AM
hunter4ever12 hunter4ever12 is offline
2000 blazer drivers side seat heater stopped working
Well as the title reads the drivers side seat warmer has quit working on high and low both. My question is before I dig into it too deep, is there a fuse and or relay I can check before i do anything else? The seat warmer was left on for probably about 2 weeks straight by my wife while she was driving it and it just stopped working. So I don't doubt the heating element is burned up but before i decide to replace it or the entire cushion I want to check the "easy" things first,if they even exist to be checked. So any thoughts from anyone?
Old 11-20-2012, 12:36 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2000 blazer drivers side seat heater stopped working
HTD fuse (20a) in the underhood fuse box...probably a problem with a element though. Disconnect the elements and measure the resistance of them, should be around 3 ohms or less. If one read "open" or is sky high, you found the problem. I think the elements are seperate from the seat coushion/pads on that one, but I may be wrong. Need to check with a parts dept to be sure.
