Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-20-2012, 10:14 AM
cherrmj cherrmj is offline
Post 98 Century front signal keeps burning out
Hello, 1998 Buick Century. I replace the front turn signal bulbs and they are ok for a week and then burn out. I have cleaned the connector, bulg socket. What do you think I should check? Other electical issues for FYI : dash light out, windows slow, wipers stop in up position. Thanks
Old 11-20-2012, 11:03 PM
stripe stripe is offline
Re: 98 Century front signal keeps burning out
It is likly your directional switch
Not sure if the century had the switch at the lights that you can change.
The Following User Says Thank You to stripe For This Useful Post:
cherrmj (11-21-2012)
Old 11-21-2012, 07:59 AM
Post Re: 98 Century front signal keeps burning out
Thanks. So you think there is a directional switch by the front turn sinal light? The back turn lights do not burn out
Old 11-21-2012, 01:11 PM
Tech II Tech II is offline
Only thing I can think of is, a circuit has lost it's ground and is somehow backfeeding to ground through the bulb......
The Following User Says Thank You to Tech II For This Useful Post:
Old 11-21-2012, 05:55 PM
I see a lot about checking the ground but don't really how to go about it. Is the ground just for this circut? Where would I start? Thanks again.
