Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-19-2012, 07:03 PM
djjm3 djjm3 is offline
1999 cooling fan will not operate
I have a 1999 Monte Carlo 3.1 motor with 180,000 miles. I changed both fan relays, the temperature sensor (and the connector), and the main cooling fan motor. The temp gauge works but fan will still not work..I swapped the relay between the ignition relay and the fan relay to make sure they worked (they all do )..I checked continuity between the sensor and the relay and continuity between the relay and the fan motor everything seems to be getting through the wiring. only thing is when I disconnect the sensor the car wont start. what could be keeping the fans from working?? Is there a separate sensor that operates the fans??
Old 11-19-2012, 07:13 PM
maxwedge maxwedge is offline
A990 racer
Re: 1999 cooling fan will not operate
The fans come on with the a/c or at temps above 222, is this not happening?
Old 11-19-2012, 07:29 PM
not coming on with the a/c or high temp....
Old 11-19-2012, 10:15 PM
Tech II Tech II is offline
You can try direct wiring the motor from the battery to see if the motor turns......or get the car warm, turn the A/C on, and give the motor housing a love tap with a hammer...
Old 11-19-2012, 10:45 PM
its a new motor would i need to do that?? I will try it tho...
Old 11-20-2012, 12:05 PM
no deal on tapping the fan motor....
Old 11-20-2012, 01:02 PM
A990 racer
Still have not answered the question, under what condition does the fan not work, over 222, when the a/c is on on a warm day?
Old 11-20-2012, 01:22 PM
j cAT j cAT is offline
check the fuses. with a meter check for voltage at the relay control contacts. check for voltage at the fan.
get the old fan connect 12 volts to it see if it runs. if it does then you may have a control/ground/connector /fuse issue.
with the ac on the fan should run.
The Following User Says Thank You to j cAT For This Useful Post:
djjm3 (11-23-2012)
Old 11-20-2012, 01:45 PM
I only had the car 4 weeks....so I never new what will happen if its above 53 degrees outside.....fan wont operate at all..even if the A/C on or when the temperature gauge is just below the red (on the right of the gauge).
However I did flush the radiator and put in fresh dexcoolant....
Old 11-20-2012, 01:50 PM
I checked the fuses- even cleaned the terminals.... there is continuity between the sensor and the relays and from the relay to the fan...no leakages (or shorts) on the wires...
I was wondering about a ground fault...where is the ground set at on that car....
Old 11-20-2012, 05:32 PM
I did some more checking. The Old motor DID work when I hooked it to the battery.I pulled the relay and check for continuity. when i looked at the pins this is what I found:
Pin 85 ( when I go to ground I get Power coming from it)
Pin 87 ( when I go to ground I get Power coming from it)
Pin 86 ( when I go to Power I get a Ground from it)
Pin 30 (goes to the sensor and I checked continuity and its good coming from the sensor- thats the Dark Green wire- the one by itself on the sensor)
Pin 86 is a Light Green wire and it goes to the fan motor and there is continuity.
thats what I found so far....im thinking that the problem is in the PCM. any thoughts on this??
Old 11-20-2012, 06:38 PM
A990 racer
You can command the fans on with a pro scanner to see if the pcm can operate them, also if you unplug the coolant temp sensor they should come on.
The Following User Says Thank You to maxwedge For This Useful Post:
djjm3 (11-23-2012)
Old 11-20-2012, 07:28 PM
I will try that...I know before when I unplugged the sensor and tried to start the car, it wouldnt start.....also what if they dont start up??
Old 11-21-2012, 08:01 AM
A990 racer
Get the car started, warmed up, then shut it off momentarily, disconnect the coolant sensor, then start it up and see if the fans come on.
Old 11-21-2012, 08:56 AM
85-86 is the coil control. 86 is the ground.
87 should go to the fan , 30 is the 12 volt feed. short out 87 to 30 does fan work ? is there 12 volts across the fan power input. do not use body ground use the return wires/ground wire.
the fat wires go to the fan motor , the small wires are the contol coil relay wires.
your finds appear wrong .
Tags
carlo , chevy , cooling , fans , monte
