Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-19-2012, 04:53 PM
TCHRISD TCHRISD is offline
Mounts help...
I am wanting to change my tranny mount and the torque strut mount on my '96 LSS. The rubber on the tranny mount broke and the torque strut mount rubber appears to be deteriorated, probably from a oil leak I had for a while.
Well I am planning on driving up on ramps and using a floor jack to lift the engine an inch or so. Then remove and replace the mounts. Will this method work? Any other advice?
Old 11-19-2012, 05:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Mounts help...
Should be pretty straight foreward, just be sure to keep the trans supported before removing the mounts!
Old 11-19-2012, 07:37 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Mounts help...
Jackstands are safer than ramps for this kind of work. There is less chance of unloading the front tires and having the car shift or roll when you move or support the driveline.
Old 11-19-2012, 08:08 PM
Re: Mounts help...
Considering these mounts are on the opposite side from one another, should I use the jack more on one side replacing that mount then re-adjust the jack more to the other side and then replace the other?
